Bathroom light-fitting spots.
21 Nov 2005
London
Can you place a spotlight light-fitting in zone 3 of a bathroom. As you see zone 1 and 2 lights but not 3 (not as much anyway).
Bazdaa
If jets of water are likely to be used for cleaning (unlikely on the bathroom ceiling in your house!) then IPX5
Otherwise, whatever you install in zone 3 just has to be suitable for the conditions that are likely to occur where it is installed (which is a general requirement in the regs for anything anywhere anyway), slightly vague, but quite a few things in the regs are
Given that the requirements become less onerous as the zone number increases, if a light is suitable for Zone 1 then it must be OK for Zone 2 or 3.....
Bazdaa
This one!
Bazdaa
OK, you know the distance is 0.6 metres from the end of zone 1 to the end of zone 2. Does that mean that any part of the light fitting must be in zone 2 or just the central housing section?
Bazdaa
Sorry I meant not be in Zone 2.
Now if zone 1 is general use, then why can the unit not go into zone 1.
Bazdaa
It all Depends on the IP rating and Voltage of the light you want to install..
(broken link i'll find a new one)
Frankly I no longer care to try and wade through all your "no what I meant" corrections to try and work out what you mean.
But I think your understanding of which zone is which might be AAF.
