- Joined
- 15 Nov 2019
- Messages
- 3
- Reaction score
- 0
- Country
Hey everyone,
Just wanted to get everyone's thoughts on my plans for just making this room look clean.
It's a spare bedroom and the flooring, walls and ceiling all had to get stripped to resolve a wiring issue.
It meant I was left with no flooring just the wood that came with house which is in pretty good shape, flat apart from a few very small nails that need pulled and some very tiny gaps in areas between the boards.
The wall is papered with an almost flat design and some areas around sockets that were plastered when they had to remove the paper.
Celiing is fully plastered and flat.
I'm looking for the cheapest and cheerful way to decorate it it is only used for storage.
Would I be able to use one type of paint ( white to just go over all the walls, doors and ceiling ? Again not caring about the finish other than it looking clean and taking.
For the flooring would I be fine dropping some Vinyl sheet flooring without underlay etc ? along as I removed anything that is likely to tear it up like nails etc ?
My DIY skills are limited so this was my idea for something I may be able to pull off.
Paint whole room one solid white let it dry then roll out the vinyl to fit the room and cut round the edges.
Thanks for any advice.
