Hello my plumbing is reasonable. I am about to remove part of a supply for a friend and can easily cap pipe as close as possible to a T junction. It is rarely mentioned but my question is...how great is the risk of stagnent water in a length of pipe which is capped and never run off periodically (eg if someone 'builds' over it). What length is considered a problem? I can imagine that water pressure is great enough to cycle water in a couple of cms worth but what about longer pipes?
Another example is in my house...new washine machine only uses cold pipe not hot supply, so there is a couple of feet of pipe with water which never moves, how often should it be run off?
Derek
Derek
