After being away for 2 weeks, I started up by my (open vented) system and no heat. There was a mains feed to the pump, but the pump appeared to be stalled (no vibration). I unscrewed the vent plug about half a turn. This caused a small water leak, but no air release as I recall. However, the pump started up and has been OK since.
On the assumption that the pump had stalled rather than suffering an air lock, does this imply that it could happen again? If so, I would need to consider a new pump as I am away a lot and need the system to operate reliably and unattended in cold weather.
Allan
Allan
