If you agree with the new regs that an RCD with a possible failure rate of 7% mitigates omitting supplementary bonding than you might decide not to do it![]()
The RCD will not protect against a shock to a person touching true ground and something connected or bonded to the "earth" CPC when the CPC derived from the neutral goes above true ground potential due to a network neutral failure / fault.
So if a 7% failure rate of RCD's is "permitted" then the far lower risk of a bouncing neutral can also be accepted by the regulations. Not much consolation for the person injured by that once before death occurance.
