- Joined
- 3 Apr 2006
- Messages
- 88
- Reaction score
- 0
- Country
i am changing the layout of a loft. steels have been laid under the timbers about 1/4 of the way up them to help carry the load of the roof. previously the roof was held up by a wooden beam running across the middle of the roof timbers and this beam was suppported by loads of upright timbers supported by the floor. the house is about 110 years old.
some of the new steels are on posts whcih rest on supporting walls. i am a bit worried that either the steeels wil be too heavy for the house or walls? or that the steels are too low to carry the weight. in particular:
1. there is one steel which has been laid across the floor (supposedly below the floor level). this rests on an outside wall at one end and on two chimney breast walls in the centre of the room. a post (which supports one of the steels which support the roof timbers) then sits on this steel running along the floor.
this floor-level steel is currently running not level. does this matter? the lower level is at the chimney stack end. is it right that these chimney stack walls are therefore taking all the weight? could this cause problems in the house?
2. some of the posts holding the steels up rest on timber. is this ok? the timber seems to run from one outside wall to probably another thick internal wall.
3. one of the steels is cementred into the wall but the post could not be used as there was no wall below this.
