The cold water tap on our bath is playing up, it will only open by about 1/2 a turn, then it stops turning, so only a trickle of water comes out. I took out the valve assembly and gave it a good old spray with WD40, when I replaced it no water came out at all! As a temporary measure I loosened the valve locking nut so the whole assembly turns, this at least lets the water flow out although with a bit of a leak round the bottom of the tap.
My question is: will the whole valve assembly need replacing or can it be dismantled and cleaned up?
And: I can't tell who made the tap. How do I then go about getting a replacement valve assembly if I need one, as I've been told that tap valve sizes vary from make to make.
