sticking tap
20 Aug 2005
Surrey
The cold water tap on our bath is playing up, it will only open by about 1/2 a turn, then it stops turning, so only a trickle of water comes out. I took out the valve assembly and gave it a good old spray with WD40, when I replaced it no water came out at all! As a temporary measure I loosened the valve locking nut so the whole assembly turns, this at least lets the water flow out although with a bit of a leak round the bottom of the tap.
My question is: will the whole valve assembly need replacing or can it be dismantled and cleaned up?
And: I can't tell who made the tap. How do I then go about getting a replacement valve assembly if I need one, as I've been told that tap valve sizes vary from make to make.
You can replace the whole valve. And I have been told that B&Q are selling generic tap valves for.... 98p!! YES! 98p. Worth a go for 98p i would think.
That's cheap! I will give it a go, even though the sceptic in me says that 'generic' means it won't fit anything properly! Ah well, fingers crossed.
Its quite easy to rectify doesn't even have to be that cheap it could be free NOW thats Cheap
