Stihl BG85 Leaf Blower Gaskets
17 Oct 2011
Glasgow
I am needing to replace a couple of gaskets on my Stihl BG85 Leaf Blower (recently acquired). I have found many sources for the cylinder gaskets and the carburetor gaskets but no one seems to be supplying the intake to cylinder gasket and the carb to intake gasket. I've started looking into buying suitable gasket material and cutting them out myself but I'm not convinced that I will achieve the precision required. Any ideas?
With suitable gasket material and a good sharp craft knife, there is no reason why you should not succeed, have confidence in your ability.
if you lightly oil the mating surface then hold gasket material over the same, rub gently and the imprint should be transferred to the gasket material, then carefully cut it out.
Wotan
