pressure washer
pressure washer
I think the key is in that shiny gate valve under the mid position valve.
But honestly I can't look at that picture for to long before the urge to inflict actual harm to an human becomes worryingly strong.
I had a system the other day with a blocked cold feed/open vent area... 13 of the 15 rads got "warm" (not hot) and the boiler cycled a lot. Draining radiators at first it was crystal clear and I was starting to doubt my diagnosis but when I cut it out the pipes... Wow. Barely a pinhole left for the water to flow through. Cleaned it out, pump valve was also full of crap (I was changing the pump anyway since it was knocking), put a magnabooster filter on and away it went. Customer said it was better than it had ever been in the last 10 years! I combined the cold feed and open vent in this case but you shouldn't need to in theory having an air separator.
If some of your radiators are getting hot then that tells you that there must be sufficient flow to make them work all around that piping.
There may be insufficient to heat all the radiators but by turning the hot ones off you are diverting that flow to the cold ones. the fact that they still don't heat properly tells you the problem lies with a blockage between the tee-off to them and where they re-join.
The fact that the cold ones are downstairs is a classic case of sludge build up as the sediment settles at the lowest point. Try taking one off and flushing it, that will give you an answer. If you don't want to do that for whatever reason then power flush might be your only optipn
Where you can just undo existing compression joints, the less cuts you need to do the better! Yes that's the air separator in pink. Obviously cut above the soldered coupling above it and leave about an inch of bare pipe if you have room (it's more than you need for a compression but I prefer to have plenty). I expect the CH pipe will only have a minor amount of magnetite but if you're drained down anyway then why not? Don't put an auto air vent back on, replace with a manual vent on an open system (they can suck air in due to the lower pressure compared to a sealed system).
