    Dismiss Notice
Stone Capping Not Adhering To Mortar?
Discussion in 'Building' started by Foresty Forest, 30 May 2021.
  1. Foresty Forest
    Foresty Forest
    14 Jan 2020
    150
    Thanks Received:
    2
    Country:
    Most of these stone cappings were loose, so I relaid them all last year. But quite a lot of them are loose again. I think the pointing is all that's holding a lot in place.
    I used a bed of 6:1 (I think?) mortar , and was careful that it wasn't too dry or too wet. I also used mortar tone, about 40:1.
    Is this one of those things that's just tricky? Is there something I should have done differently? And is there a quick fix for the ones that are loose?
    [​IMG]
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    33,999
    Thanks Received:
    4,615
    West Mids
    Country:
    It should be a 3:1 mix and the important thing is for the cappings to be squeezed down, slid or tapped into wet but not soaking mortar to form some suction and get a good bond.
    The joints should be put on the capping stone and compressed likewise, not put in afterwards.
    • Like Like x 1
  4. catlad
    catlad
    29 Jul 2011
    4,912
    Thanks Received:
    743
    Lancashire
    Country:
    A slurry mix on the stone to be layed will help bonding.
    • Thanks Thanks x 1
  5. mrrusty
    mrrusty
    1 May 2018
    737
    Thanks Received:
    147
    Country:
    add some sbr to some cement to make a slurry. Paint the back of the copings. They won't shift then. wash off any splashes immediately or they'll set solid.
    • Thanks Thanks x 1
  6. Sponsored Links
  7. Foresty Forest
    Foresty Forest
    14 Jan 2020
    150
    Thanks Received:
    2
    Country:
    Thanks. What's a slurry mix? And is this something I can use on the loose stones now?
    Btw. I did use 3:1 in the first place, so has anyone got an idea what went wrong? Is it that stone is just non-absorbent and repels mortar?
  8. mikeey84
    mikeey84
    7 Jan 2011
    1,235
    Thanks Received:
    137
    Warwickshire
    Country:
    Mix pure cement with enough water to make a consistency like double cream. SBR can also be added.
  9. Foresty Forest
    Foresty Forest
    14 Jan 2020
    150
    Thanks Received:
    2
    Country:
    I have some ready mix acrylic wall tile adhesive - would that work to quickly reattach the loose stones?
    Or would the slurry mix be a quick fix?
  10. bsr
    bsr
    5 Aug 2008
    591
    Thanks Received:
    53
    Gloucestershire
    Country:
    I would use powdered tile adhesive but not ready mixed.
    • Thanks Thanks x 1
Loading...
Share This Page
