Stop cock off - cold water still running upstairs?
31 Dec 2013
Berkshire
Hello!
Thanks for advise so far.
Stop cock is turned off but cold water is still running upstairs? As the cold tap has seized i cant test that but the outside goes
Off - why would the upstairs still be running ( and before you ask i have turned off the stop cock on the mains and not the one leading to the outside tap)
Thanks[/i]
31 Dec 2013
Berkshire
Probably tank fed.
What type of system do you have?
Yes i do have a water tank, as the cold tap is def off the mains i can be certain once i disconnect it the water wont come out?? I assumed all the cold water would be off the mains.
I guess to be double sure i could turn off mains and run the bathroom cold taps?
Btw - wouls i need to drain down the hot water too before i remove the tap?
