I doubt that all stopcocks are the same design but in the type I'm thinking of the washer and the part that holds the washer aren't lifted of the seat by the spindle turning, they are lifted by water flow from the mains side. This doesn't work very well in reverse. Also think about which side of the valve the spindle gland is. If you fit it the wrong way round you won't be able to shut off water pressure to the spindle gland if it ever needs attention. .
