Stopcock on mains water
Water can leak out past the spindle glands, oil can not leak in
What's the point of using it then if the oil can't get to the internals, that can be where the tap invariably seizes up. If it's just the gland then loosening the gland nut will free that up to allow it to turn again. Invariably though an old stop tap will seize up further down the spindle and into the tap internals or the internal head gear thread is worn and it's jammed. When WD40 is used, it acts as a penetrating lubricant and can work it's way down into the tap internals.
I've serviced taps in the past where WD40 was used to free it up and it's worked it's way down, broken down the original grease inside the head gear and could be tasted in the drinking water. Thats why I never recommend ever using a penetrating oil and why a stop tap really needs broken apart and the internal machine threads re-greased (silicone), amongst other things, for it to be serviced properly.
Sometimes the physics don't marry up with the real time experiences
I managed to move the tap back and forth before it was then moving freely. I did apply a tiny drop of 3 in 1 on the thread - prior to reading @Madrab’s point above.
This freed the tap but it then started dripping from the nut near the spindle. I nipped this up slightly and it’s now stopped. My tap seems to be covered in muck. Possibly cement from when we had the extension work done. Notwithstanding the point above, can I apply some sort of solution to clean all this up? It will probably help with the reliability of the stopcock.
I was tempted to replace it but couldn’t get the stopcock on the pavement to work either. Will put a call into Thames Water
