Stuck radiator valve
23 Jan 2012
Essex
Hi there. I have been checking our radiators for the upcoming winter (ironically, over the hottest weekend of the year) and one of my radiator valves is stuck closed, so I cannot bleed it. I bought a radiator key but it is too big - in the past, I have just used a pair of pliers but they just won't budge it this time. What are my options?
I can either continue to have a go with getting the tiny square screw open or should I cut my losses and try and replace the entire valve with a new one?
Get a socket set.
Find a socket smaller than grub screw that don't fit on.
Couple of smacks with a hammer will shape the brass to the socket.
Very often the bleed screw comes loose when I've done this in the past.
If not when socket it's on use your socket wrench.
I've advised customers to get the radiator replaced as that's a cheap DIY job if you are game, and looking at the rust and corrosion in picture I would advise you do that sometime before winter this year.
Thanks guys - I shall see if I can get through this winter and aim to upgrade all my radiators, next year - they are all very old anyway.
I drained my system down, to put TRVs on every radiator so this radiator does need bleeding as it is empty.
Slightly off track but the radiator that needs bleeding is a long single one that bends round a bay window - what would I update that with?
The reason I ask is that I have seen photos of people replacing these with two doubles instead.
if he sticks a pic up of the otherside he maybe able to change the plug to a bleed
Get a socket set.
Yes, the bleed screw may come loose after smacking with a hammer but, with that amount of rust, there's a danger that the whole bleed valve will come loose and leak or, worse, come out completely. If you don't want to renew the radiator for now, I'd leave well alone.
I am not a plumber...
If you can lift the rad off the bracket, you can loosen the valves and tilt it just past horizontal. Any air in the rad will move towards the rad valves. You should be able to remove most of the air.
I have only done it once, it seemed to be about 80/90% effective.
If you look at your rad key you will notice that the square hole which needs to engage with the bleed screw is recessed by a couple of mm. If you file the end of the key down (easy as its only soft brass), the key will engage much better with bleed screw.
