    Dismiss Notice
Sudden loss of pressure - Heatrae Sadia Megaflo
Discussion in 'Plumbing and Central Heating' started by Ben B, 15 Mar 2010.
  1. Ben B
    Ben B
    16 Oct 2005
    52
    Thanks Received:
    Suffolk
    Country:
    Using the shower tonight the pressure suddenly dropped. The whole house now gets a not-very-pressurised water flow. It has always been fantasticly powerful.
    So I looked in the airing cupboard, the pressure guage at the top of the tank is only Reading half way towards the green zone. So I turned the valve tap I usually go to (well, last time it did this about 6 months ago) that usually makes the pressure guage go back up again, but it did nothing. I'm sure normall there's an audible hiss as the pressure gets let back in?
    Any ideas?
  2. crockett
    crockett
    15 Mar 2008
    916
    Thanks Received:
    32
    Berkshire
    Country:
    What's the incoming pressure at the first cold mains outlet into the house like? If this seems to have dropped, that could be one reason. Another reason could be a blocked filter in the combination valve on your magaflo, or failure or the built in pressure reducer. How old is the megaflo ?
  3. Sponsored Links
  4. Ben B
    Ben B
    16 Oct 2005
    52
    Thanks Received:
    Suffolk
    Country:
    Yes, the pressure at the first cold tap in the house isn't what it was either. I actually went outside 10 minutes ago and overheard one neighbor askng another if there pressure had dropped and that Anglia water are looking into it, so I think that answers that then!!
    Thanks for your helpful response though!
    One other thing- while checking out the boiler I noticed the electrical fused switches on the wall and realised I don't know what they do- one of them switches off the timer/switch wall unit, but the other leads straight to the bottom of the cylinder- both are swithed on. Is the second one supposed to always be on? It's been on for about 2 years. I just had a sudden fear that I could be the emmersion heater for the water, if it is surely I've been throwing money away on heating it constantly?? I it isn't then I don't have an immersion heater switch- is this normal?
  5. muggles
    muggles
    28 Oct 2005
    13,067
    Thanks Received:
    2,950
    Daventry
    Country:
    Second switch is almost certainly the immersion. A good way to confirm this is to go and look at how fast your electric meter is spinning, go and switch it off then look at the meter again. If it's slowed down noticeably then it's the immersion.
    As for the pressure gauge, this is probably connected to your heating system and not your hot water system so opening that tap won't really help
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
