Hi all,
Going to be renovating our bathroom myself & looking for some advice on which is the better/correct way of powering the LED in the shower niche & under the vanity unit. I will be using IP65 LED strip lights powered using a 12v/24v LED Driver
Method 1
Spur off the existing bathroom lighting circuit & wire it up like most common lights. i.e. Spur to junction box with power to LED driver & another to a 2 gang 1 way switch. With this I would be placing the driver in the ceiling (loft) running two 12v cables one for shower niche & other to vanity unit. This way if driver ever fails then i can replace/maintain in the loft.
Method 2
Again spur of existing bathroom circuit to the light switch (2 plate method). From light switch I would then run feed (supply) to LED driver stored somewhere in the bathroom (under shelves or vanity unit out of prohibited zones) & rest will be the same shower niche & vanity unit etc.
I have concerns with both methods, method 1 is having the led driver in the loft, will most prob have a fire hood over it but will it be a fire hazard?
With the second method, since I want use a 2 gang 2 way switch (one for existing bathroom lighting & one for new LED lights) will this be a issue having two types of wiring in the light switch?
Is there a prefered/correct way of doing this? I want to get all the cables installed correctly before a electrician checks it all, the last thing I want is bathroom all done & having to re-run all the cable again etc.
Appreciate your help in advance
Method 1
Method 2
