Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Is it ok to have 2 pumps and 5 40W lights oin garden, supplied from a 6A MCB on the RCD side of CU, without having any external fuses before the equipment, ie FSU?
If it's already fused down to 6A by the MCB, you don't need to fuse it down again. If you put a 5A or even a 3A cartidge fuse in an FCU, the MCB would probably still trip either first, or at the same time.
