Does a an outside light still need an FSU switch with a fuse?
The regs don't require anything (if it's fed from a 6A lighting circuit) - but if you don't have a DP switch, you might come to regret it if/when your outside light fills with water and trips your house RCD.This will most prob be off the lighting circuit, so need for a fuse. Double pole make sense of course, which will most prob be the case, but what do the reg's say? Or what do most do?
