I have a 1930's single brick built semi. The chimney breast is tied into the wall. As far as I understand, if you want to remove a breast inside the house the stack can be supported in the loft by a steel bra arrangement or an RSJ.
The outside wall is brick but the internal wall, which would support the other end of the rsj is the old cinder block.
What are the pros and cons of the two methods?
BTW, I am not planning to do this work myself.
