supporting a shed base
6 May 2017
Hi all I've joined the forum in the hopes that some one can help me. I've got a shed in the backyard that's been up about 6 months and we still haven't finished it.
The electrics need to go in and I want to make the base firmer.
its the base that's the problem. The shed is currently sat on wooden beams that are sat on blocks and is approximately 21cm's off the floor, but the blocks are only at various points under the shed. I need to put some extra bricks under it so that when I place in the new flooring I want to put in and the cupboards that it will sit firmer on the blocks (the idea being the extra weight will cause it to sit on the blocks properly).
Because at present when I step on the floor where there's no bricks you can fill the floor give slightly.
I have no idea if I'm making any sense here but basically I need to add extra bricks but am not sure of what to buy other than it needs to be weatherproof and a couple of mm's under 21cms's in height.
