Suprima50 pcb fitted. Now no ignition
27 Nov 2005
Hi All. I have just replaced the old pcb with new improved variety 5111603. It now goes through start up routine up to flashing orange/green, the fan starts, but no ignition occurs. After a minute or so the fan stops and the led goes to flashing red 3 times/sec, indicating an APS problem. I notice that from the instructions, no earth is required to the fan??. I also did not remove the fan. What do I need to do now?
Couple of times I presumed I had pushed the ignition lead onto the pin on the back of the board but had actually missed...worth checking.
I would recon that you have got the pipes the wrond way around on the pressure switch
Thanx chaps, will check these out on next visit to girlfriends boiler, not that my girlfriends a boiler of any sort, but ........ why am I nexplaining this to you.
