Each mm you progress the resistance will increase exponentially.progress is slow, but.... Well, progressive.
I'll still need to get a 1200 / 1500 long bit to finish off, but hitting 600mm, so far, so good I hope.
I've got a feeling he's about to learn more about the clutch on that drill, than ever before.I guess it's got a clutch
It really will.No, it really won’t.
It really will.
At twice the depth (600mm vs 1200mm) the resistance will be a lot more than double.What’s your rationale for that?
Of course it will increase, but no way is it exponential.
At the risk of vanishing down a really boring rabbit hole of pointless waffle, the resistance will increase in a linear way. The drill speed will slow more than linearly, possibly exponentially due to the increasing resistance.
Whatever though, it will get much more difficult!
Not all the material is cleared, not even close. It takes a lot of clearing even at 300mm. The deeper the hole, the greater the build-up of ground up material.Not necessarily...
An sds drill bit, has a spade type tip, which is slightly wider that the shaft, which means it will drill itself a clearance sized hole for the drill shaft. The only way the resistance will increase dramatically, is if the is damp and the damp soaks the drill dust enough, to cause it to jamb the drill.
He's awaiting quotes to rescreed that hallwayHave you really been driling for four days?!?
Oil wells have been drilled quicker. Have you either finished or ruined your hallway yet?
