We are currently undertaking to replace the lead pipe in our house, it has been approved so they are coming to mole next week and then approve the replacement the week after....
However, I wanted to get some opinion/advice from people. I have seen lots of information on suspended floor insulation. I am planning, once the pipe is replaced to install insulation and keep the room warmer.
I am not 100% sure on which insulation route and method to go as yet, but noticed a couple of people have used a DPM on the top layer after insulating with the wool or glass products.
Regardless if you used the DPM or any other products on the top of the joists, I was wondering rather than installing the floorboards back down would it be ok to install a solid walnut floor on top?
Would I need to do anything else to install it directly without having the floor boards? The reason why I would prefer this method is the floor is 1 inch thick which is very thick and if you add the boards then you are rising very high above the level of the floor. I wanted to try and avoid this.
