Hi all,
I would like to run some cable for a few sockets around an outhouse that is attached to the side of the house. I am planning to use SWA cable as its an old structure with some wooden beams, tends to get somewhat damp and we can get rodents. Also I can get hold of some spare 4mm 3 core SWA from my dad.
If I run the outhouse wiring as a separate circuit from the CU would 4mm SWA be enough for 4 double sockets? It would be running a washing machine, tumble drier and freezer, and occasionally maybe a power saw or drill.
Secondly I'd like to move our electric cooker to an external wall and fit an extractor hood. This requires a new run of cable. We may upgrade to a double oven eventually. Would 4mm SWA from the CU 'future-proof' it, and could the hood be run off the same supply?
(I accept I could use T+E, but we have had rats in our ceiling space previously (old building) and besides I can get SWA easily enough).
A part P person would check everything and connect to the CU, but actually running the cables, siting the socket enclosures etc, besides taking up carpets to run cables etc, requires quite a bit of basic manual labour, which I could do myself
Thanks for advice and suggestions
