G
Goldspoon
Am fitting a 1600 litre tank that will collect rainwater from guttering. Task is to use this water to supply one WC cistern in a holiday home. At the moment the cistern is filled by a pumped source - from a well. Reason for doing this is that the well can run dry in the summer.
Problem is that I want to add some kind of lever in the WC that can be switched between "Tank" and "Well". Is their such a lever or switch somebody can point me to - or a workable solution using normal plumbing devices...
