Switch from heat only to system?
6 Mar 2020
Currently have an unvented system + cylinder with a heat only boiler. Looking at specs heat only boilers seem less capable and of significantly lower spec especially in terms of things like range rating, modulation, weather comp etc?
1. What is typically required/involved in switching from unvented heat only to system?
2. What are the pro/con of each type?
TIA,
