Switch inward opening uPVC Bi-Fold to open outwards?
2 Sep 2010
London
We have quite a large uPVC Bi-Fold door (2.4m x 1.9m) which was supposed to open outwards. The builder screwed up and ordered it inward opening.
At the time they were more expensive then now. So rather then jeopardise the rest of the job (he may well have tried to find a way to make up his loss) I came to an arrangement with him.
Now we're getting a larger dinging table it's causing a problem :( The cost of a new one will be ~£2k, so i'm wondering if it would be possible to reverse the entire frame.
This will mean the beading will be on the outside. And also the fittings will have to be switched around with the holes on the other side covered in some way. But wondering if its worth getting someone to take a look. Or if its a waste of everyones time.
You will need to redo the drainage as well
Thanks for the reply.
Do you mean the drainage holes in the doors? I envisaged rotating the frame 180 degrees so inside is outside. In which case the doors would be the same side up.
drainage will still be at the bottom but will be facing inwards so will probably need to seal up the existing holes and redrill new in sashes and bottom of frame
Ahh, I understand now. Thanks
Will the locking bolts end up outside?
I think its unlikely the cill will work.
Give the manufacturer a call, they will be able to advise how universal the bifolds are between open in and open out......
Yes the existing handles would end up outside. Would have to fit new ones on the inside, aswell as the bifold hindes/etc.
It was a whole house refurb and the windows were included in the builders contract. It's been quite a while and he's no longer operating. Don't have the manufacturers details :( I guess my other option is to lookout for a cancelled order/clearance that will fit. But will likely still be expensive and not match the french doors/windows in the same room.
To find manufacturers details have you opened all the doors and checked all edges for manufacturer label or stamp (mine is on hinges).
Sfk
Sfk
I did have a look, but the bi-fold doesn't have any stamps on the uPVC profile that I can see. The hinges and metal mechanism inset into the doors is labelled SI.
The French doors and windows are all stamped Rehau along the uPVC profiles.
Get new doors made and sell the old ones to recoup some losses. Also get a proper window fitter to do the install/survey.
