Hi All,
Does anyone know if there is a direct replcaement for a Switch Master Midi Valve Actuator VA1?? Ours hasn't worked since we moved in and I have to thrun the valve by hand!! I have seen other 3 way valves but the motor box is in the wrong plane and would require the system to be drained and modified to fit..
I have done a search but no luck...
Thank you,
James.
Thank you,
James.
