S
Shutpa
One of the rockers came adrift from neighbours 2 gang switch one of which is a 2 way. Behind the switch in the box, there are terminal blocks with cables isolated and on the reverse of the switch between the common terminals of the two switches, there is a piece of flex connecting both and also a red (live?) connected to one of the common terminals. Correct me if I'm wrong but I always thought that the wiring of such a double switches should be completely independent of each other and that 'flex' should never be used on 'permanent' house wiring.
