switchmaster actuator midi I need one please help
12 Nov 2010
London
I need a switchmaster actuator midi, I know they are now obsolete but if anyone knows where I can purchase one My son and I will be grateful, forever. Thank you
You'll need to change it for a more conventional mid-position valve. Someone will know the wiring connections.
Blimey even the ebay clearouts finished about 8 years ago, just change it rewire is very simple been posted up on here lots.
can you recomend a brand and a shop to get a new thing and roughly how much are they?
Thanks for replying, sue.
The wiring goes like this, for most current valves which could be used as a replacement...
[code:1]Switchmaster ................... Honeywell etc
Blue ............................ blue
green/yellow......................green yellow
yellow............................white(poss brown if no white)
white.............................grey
orange/ red link together.........orange[/code:1]
A new valve will cost £50 - £100 depending. There will often be a need to alter the pipework, though you might be lucky. Depends on the location exactly. It'll probably be drained to some extent.
Total cost could be in quite a wide range, but £200 might be typical.
Thank you for getting back so quick, I don't think my plumber wants to put a different one on, he told me to source an exact replacement. I have read some of your posts and you seem to be the oracle Chris. Thanks again.
I dont think hes really a plumber then as we all know they havent been avaible for years and its not exactly a hard job fitting a replacement even with pipework alterations
There is a brown switchmaster valve aswell, although I have only ever changed one of these and I remember it to be horrible needed all the electrical controls replaced.
