taking a single phase from a three phase socket.
14 Nov 2005
Need some pointers if this is ok.
Need to get 3 two gang rcd protected socket fitted in three welding bays. Each bay has a 32 amp three phase sockets on a 32 amp mcb. Would be a nightmare to run in 3 new circuits as building layout is rubbish. Quickest way would be to take 4mm cable from a phase in each 32 amp socket and fit it into the 2 gang socket. ELI is well below the max and the extra load is for grinders. The 2 gang socket would be next to the three phase socket with a bush joining the two.
Thanks in advance.
You should be looking towards using RLV (110v CTE) for hand held tools such as grinders.
