Hi All, my dad has a problem with his gas central heating system, its a Ideal Standard I-Type RS ( 1975 ). The problem is that the small tank in the loft ( header tank / expansion tank or whatever its called - keeps central
heating toped up ) keeps filling up and over flowing, he has checked the ball tap and that's fine something else is causing it. If you hold the ball tap up so that NO water comes from the pipe at the top the water still comes in, looks like its comming back in the tank from the pipes at the bottom of the tank that go to the central heating system itself. Why is the central heating system causing the tank to fill up and overflow ? What can the problem be, what can be checked or tried next ?
Thanks, Duncan
Thanks, Duncan
