I have a system that has a pump for the central heating and also another grundfos pump built into the hot water side of the system.
The tank is a two part one with hot water below and I presume the f&e tank above.
The hot water must be linked to the mains as there is no header tank to feed the hot and the flow stops when the mains supply is turned off.
The problem seems to be that the hot water pump is constantly running and seems to be slowly filling the tank above it which is then flowing out through the overflow.
It's definitely not the filler for the upper tank as I have turned that off.
Any help would be much appreciated.
