Tap connector sizes explained
16 Mar 2005
Could someone clarify for me the terminology used for plumbing pipe sizes? It seems to be a mixture of imperial and metric!
I want to buy a flexible tap connector for my bath that connects a 15mm copper pipe to a bath tap tail.
I haven't bought the new taps yet, but I have the impression that all bath taps use a 22mm size tail. And all basin taps have a 15mm tail.
So, what connector size should I go for?
Mike
Bath taps generally have a 3/4" threaded tail, and sink/basin taps 1/2".
They usually need fittings to connect to 22mm and 15mm pipes, respectively, though some bath supplies are 15mm too.
the tap connectors are what is nown as BSP (British standard pipe) and the size relates to a nominal bore (inside diameter) normally of brass or steel tube (e.g gas pipe) so a 1/2 BSP thread has a bigger diameter than 1/2"
The compression connector at the other end relates to the outside diameter of the copper or plastic tube you will be connecting to.
For a bath I would expect 22mm to 3/4 BSP although the cold may need a 15mm to 3/4BSP
