Tapping into an existing sewer pipe.
26 Jul 2011
Sussex
I am hoping to convert my garage into a kitchen/diner and will need to tap into the drains to provide access for sink/dishwasher/washing machine waste.
Any ideas on how this is done?
Thanks in advance.
Dig hole. Cut drain. Insert branch connector/manhole. Backfill.
I assume you’re aware that what you’re doing is controlled building work, subject to Building Regulations, a Building notice submission & inspection? & not just connecting into an existing foul drain!
jeds
Can you be a bit more specific?
Richard
Yes, aware that BC need to get involved.
I honestly can't think of much more to add. Work out where you want to connect - dig down and expose the pipe - fit in the appropriate channel/access, get it inspected and backfill. Which part of the operation are you unsure about?
Here is one I did earlier :lol:
Dig trench
View media item 37306
Make hole in floor
View media item 37300
Lay pipe through floor hole, in trench & connect to inspection hatch
View media item 37303
In this case it's a connection to an existing hatch but you may need to install a complete new hatch.
Finish off drain connection including DPM repairs
View media item 37305
In light of your question are you sure you have enough knowledge to get to grips with Building Regulations requirements & what your LABC will expect in order to complete your project satisfactorily. :?
Are you aware of the depth of your drains?
Are there any inspection chambers on your property?
