I'm just after some clarification on what it actually means. I know you should get about 11C on a conventional boiler and about 20C on a condenser but if it's low, say 6C, what would that indicate?
I had that today on a micron/s-plan/sealed system/with bypass, complaint was int overheat which I didn't actually experience myself.
I know if temp diff is too high it means there's too little flow around the boiler so if it's too low does that just mean flow rate is too high? Could it mean the boiler/pump is oversized?
Thanks!
Thanks!
