Temperature adjustable ceiling lights
20 Jun 2005
Stirlingshire
Hi Folks
I'm after some buying advice for ceiling lights.
We live in a late 60's bungalow which has a full length dormer extension in the roof.
I am in the process of modernising the upstairs hallway.
There is no natural light in the hallway except the little glass panels above each of the room doors.
I would like to incorporate some sort of ceiling lighting that would emit a cool daylight temperature during the day and that would change to warm in the evenings. Does this sort of set up exist ?
The ceiling doesn't sit very high so I'm not looking for anything hanging to much.
Many thanks :-)
Obviously there are smart bulbs, which would work out very expensive if you wanted lots of them. There is also Osram Relax and Active, in a GU10...
https://www.lightbulbs-direct.com/osram-led-5w-gu10-spotlight-relax-active-36/
When you first switch them on, they are warm white every time, then, you click the switch off and on again and they change to cool white.
edit: LEDvance do a similar thing in an Edison screw lamp.
https://www.ledvance.com/consumer/p...lamp/led-relax-and-active-classic-a/index.jsp
