I have an old (approx 12-15yrs) combi gas boiler.
We used to have a problem that the hot water temperature was very inconsistent, requiring constant fiddling with the taps to get hot water. We've recently had the boiler serviced, and the heat exchange plate de-scaled which has improved matters considerably. Other than the scaled up heat exchange plate, the boiler was given a clean bill of health.
However, despite the recent descaling, we do still have a problem that the water temperature is not totally consistent - the main issue seems to be often if you open the hot-tap immediately to full-flow, then it will tend to only deliver tepidly hot water. If I partially open the tap to mid-flow until the water has heated up fully, then slowly move to full-flow, I can usually get a consistent flow of very hot water, although it sometimes takes a few attempts - very annoying when trying to take your morning shower!
Despite the age of the boiler we are hoping to avoid forking out for a new one unless absolutely necessary as we don't expect to be in the house for more than a few years. Any suggestions as to what the problem might be?
