Texacom Premiere / Elite
7 May 2023
Hi, can any one tell me where your BT line would be terminated in the Texacom Premiere/ Elite Panel please.
On the com2400 module on top right corner of pcb. This depends on a 2400 module being fitted.
If unsure then post photo of pcb.
PSTN telephone lines are being turned off by 2025 ? and your and your analogue phone line will no longer work.
What are you connecting telephone line for ?
I am fitting a mini air, and this needs to be connected to the main panels incoming BT line. The panel needs to see an incoming line.
Thank You
Yes, but it still needs to be wired in and needs power and bell trigger. Thanx
I think what they they are getting at .."is it can be connected to the comm2400 it works like a gprs phone line ….we have a few connected like this ( guardtec 593/595 ) as you get the full fast format pins ….
+ & - aux power on pcb
In {white wire} to Bell trigger output will give you intruder signal.
You can wire as dial capture,but you will need com 2400 module.
CSL app or monitoring station?
