I have a Premier Elite 48 with two Odyssey sounders, which was 'professionally' installed but which I now look after myself, after some very helpful advice here a few months ago.
Because of some work that I'm having done in the house I will need to disconnect the cable from the panel up to the sounders and re-run it by a different route.
I would like some advice on the best way of disabling the sounders while I do the re-wiring job, which I intend to complete within a day. Ideally I would prefer them not to sound at all.
I know the three-strobe-flash trick to temporarily disable the sounders, but will they stay in this condition if I disconnect all the wires?
There is a junction box in the loft where the rising cable from the panel is split to the two sounders, and I'll be connecting the new cable there. I've thought of removing the battery from the panel and temporarily connecting it there to maintain the sounders. If the 12v is temporarily broken after the strobe trick, will the sounders trigger?
I'd prefer not to have to get to the sounders outside if at all possible.
There's probably a better way of doing this - any advice will be very gratefully received.
