The difference between pressure and flow
3 Sep 2003
Can anyone tell me what the difference between pressure and flow is. How are these related? An how can each be calculated?
Yours
Jack
Pressure diffrence is what causes flow to happen.
If you have a high pressure diffrence then a large flow will be the result, unless you have some sort of restiction like a small bore pipe in between the two. This will then reduce the flow. There is a formula to calculte flow rates but i dont know what it is. One thing for sure is that if you saw into a rising main there is a LOT of flow...........
Pressure is force divided by area P=F/A. Flow is movement of a substance which will have a msaa (weight divided by acceleration due to gravity m = w/a) force makes a mass accelerate
The calculation is
P = Q2 f S L K / d5
where:—
P = pressure loss, bar.
Q = flow in litre/s for liquids m2/h at 20°C and 1016 mbar for gases.
L = length of pipe, metres.
d = dia. of pipe, mm.
f = coefficient of friction.
S = specific gravity, relative to water for liquids, and relative to air for gases.
K = a constant and is 3.25x l07 for liquids, 3.05 x103 for gases.
For the full version see here
Pressure is what keeps a balloon inflated, flow is what makes it fly round the room :lol:
