I'm curious about a bit in the on site guide where it is describing earthing of socket finals in high leakage current situations.. It states that ring finals must use sockets with two earth connectors, and that the loop in must be in one connector and the loop out must be in the other
I've wondered about this ever since I watched my spark wiring my house sockets in this fashion(I doubt it's a high current situation as I don't have large numbers of switched mode devices, but he's more often doing non-domestic work so maybe he just does it by nature of repetitive behaviour)
What advantage does it confer to introduce an increased number of joints/potential failure points into a single CPC run? I sort of understand the requirement to have them connected to separate terminals at the DB, increasing resilience in case one connection is poor/screw stripped etc(but you'd think that would be obvious) but I can't fathom why it's better to loop the incoming CPC into one socket terminal and the outgoing into the other terminal?
Reading around I found references to systems of two separate CPCs per circuit in high leakage situations (and I can see how using different socket connectors for that would be sensible), but the OSG diagram doesn't seem to portray that
