Hello,
I've trawled through many of the previous postings on parquet flooring looking for answer, but it would be good to get fresh opinion on my particular situation.
Basic query:
Does anyone know where I can buy new parquet flooring, in pre-made baskets, as opposed to reclaimed single blocks that I have to scrape? Preferably in Surrey or thereabouts?
Background Info:
We've moved into a 1960s ground-floor flat that has parquet floors composed from teak/mahogany blocks measuring 7/8 inch (2.3mm) wide, 7.5 inches (11.5 cm) long and approx 5/15 (8mm) thick. They were laid in square baskets of 5 strips, onto a combed layer of bitumen over a concrete scree floor.
Extensive water penetration next to the kitchen and patio door and caused the bitumen adhesion to fail, meaning I can lift handfuls of blocks without effort. I have roughly 6 quare metres that needs relaying, and plenty of old blocks, thanks to a neighbour throwing out a load of identical ones. (Some top Womble-in-skip action that).
However, an experimental block cleaning session (getting most of the bitumen off with a paint scraper, then knocking crusty varnish/glue off the all four sides), has shown it takes roughly 1 minute a block, and there are approx 360 in a square metre.
At the risk of sounding like a fair-weather DIYer, that sounds like a slow form of hardwood-based masochism. Then there's the small matter of laying these tiny blocks, one at a time, making sure they fit level, and gluing all the sides to bond them together...
So, unless someone has a great 3-blocks-a-minute method of stripping that very, very sticky bitumen off (leaving fetching almost-flush zebra stripes - not completely bare timber), then I'm really keen on the 'buying in new' option.
If it exists that is.
All suggestions welcome. (Short of using child labour).
Basic query:
Background Info:
