first a bit of back ground to the problem. I have a Potterton performa 28i which has just had the Diverter valve changed. Since changing this, only half the heating appears to work (upstairs).
The downstairs radiators have hot water getting to them, but is cold at the return side. I have cracked one of the return pipes and surprise surprise the radiator starts to get hot.
I was thinking that there as a blockage in the downstairs manifold or something. So I tried putting a hose down the return of one of the bad radiators and draining through the drain pipe. So the mains water flushed back through the manifold and out through the drain. No issues!
I then started paying more attention to the Boiler again. The first thing is the boiler is certainly a lot quieter than it used to be! the next thing, when heating from cold, the temp lights go from 20 to 80deg in around 30 - 45 seconds. So I was thinking. Could the pump be on the blink? I opened the big vent screw while the pump was running and the water only trickles out. I was expecting it to p*ss out?
I'm getting desperate now and need help! My next 2 thoughts are, strip the pump, then try pouring sentinel 800x into the radiator!
Any suggestions?
Any suggestions?
