Hi again
I've not got around to tackling it yet, but when I do I'm presuming the cement that's there at the moment will be crumbly in some places and not in others. The stuff that is not crumbly..... should I leave that as is and just add the new fire cement to it? Or should I try to remove as much of the old stuff as possible?
Part of the reason I ask is because I've been told there will be a rope beneath the cement and that it could be asbestos. So I have also been warned not to use a vacuum cleaner (as I might spread the spores around).
Iif I expose the rope at all, would you guys be able to tell if it is asbestos or not from a photo? If so, I'll take one and at least I'll know what I'm dealing with it then. I can only imagine cleaning all the mess with a dust pan is going to be a pain because the dust will be fine and no doubt each some awkward places. Not that I won't manage, but if it turns out there is no asbestos at least I can then use the hoover and save a lot of hassle.
Thanks once again for all the help.
Max
Max
