The TRV with non condensing boilers?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
The TRV and lock shield valve are critical for the condensing boiler, or it will turn down output prematurely, but what about the non condensing on/off boiler?
A mechanical TRV may easy have 2°C between fully closed to fully open, in some cases more, an electronic likely more like 0.5°C but the anti-hysteresis software can be OTT.
Allowing water to return at near the temperature it left the boiler is not going to close the boiler down, so does it matter?
With 15mm pipe work, leaving the lock shield wide open, likely will mean some radiators starved, but with 8mm micro bore that is unlikely.
So clearly using TRVs so unoccupied rooms not heated is good, and those occupied do not over heat, and with electronic heads, they will work well, not so sure with mechanical heads.
Thoughts welcome.
Are digital "TRVs" actual TRVs or do the just use stepping motors to open/close a valve on the rad based on the air temperature at the sensor heads?
There's a few fundamental problems with true TRVs. One, is that they run out of control once the return temperature gets down to the same as the room temperature and then only give on/off control and, while the hysteresis isn't bad at ~ 1Deg C, the sensor head is slow to react to temperature changes due to its liquid/wax content leading to room temperature overshoot/undershoot. However with a constant 65C flowtemp, the rad output can be as low as 35% so not too bad. The The other far greater challenge is that the flowrate is very low giving a huge dT, if one had 15kW of T50 rads, see below.
I am going to have to re-read a few times, the electronic TRV head does open and shut the TRV in steps, one hears the motor run for maybe 10 seconds as it is adjusting, every Saturday at noon the valve is exercised, and it takes around 4 minutes to fully open, then fully close, then return to setting, it does not sound a long time, but I know in my mothers house with a condensing boiler, the radiator could get stinking hot before the TRV closed, so I used the TRV report Flat Battery TRV.jpg and if current exceeded target, I would close the lock shield valve a small amount, so the speed the radiator heated up was slow enough for the TRV to control it in time, to stop over shooting.
However the same idea here, does not work with a non condensing boiler, with micro bore, the lock shield valve is nearly wide open, I don't hear the TRV head motors running that often, and batteries do seem to last, so they are working, but clearly not the same as with mothers set up, hence the question.
I know with mother old house, when sold on her death, new owners did not want the electronic heads, so swapped back to mechanical heads, and now the lock shield valves already set up, it worked well, even with mechanical heads.
The problem with mechanical heads is no 20°C marking, so you have two devices, lock shield and TRV, and no idea which one needs setting.
With a mechanical head on a TRV, I note set at say 2.5 it will be fully open at 17°C and fully closed at 21°C but as to if the room settles at 17°C or 21°C or anywhere in-between seems to be down to room size and outside temperature, where with an electronic head set to 20°C it starts to close at 19.5°C and is fully closed by 20.5°C so room size and outside temperature have a lot less effect on room temperature.
Linked to boiler TRV heads may work fine with a radiator on an internal wall, but when the radiator is on an external wall, the wall cools the TRV head until the thermals have been established. So it will turn the boiler on prematurely, OK it will not run for long, once air starts to move, the TRV measures true room temperature, but still not desirable to have boiler fire up when not really required.
There are systems which can use a thermostat on an internal wall, the Drayton Wiser for example, but the cost becomes eye watering, so most of my TRV heads are not linked, and will only heat the room if the boiler is already running.
So the TRV heads are often set a little on the high side, want the room at 22°C but TRV head set to 24°C in my living room, as in the main the boiler will turn off before the room reaches 24°C anyway. This was not clearly the case with a condensing boiler, where rooms would be spot on what the TRV was set at.
So 11 pm the TRVs in living room turn down so boiler no longer heating that room, and at 9:30 pm the bedroom TRVs also turned up, giving 1.5 hours to heat bedrooms before the boiler turns off, the living room wall thermostat will also turn down at 11 pm, and the linked to boiler TRV in wife's bedroom will fire the boiler if her bedroom drops below 16°C.
The hall wall thermostat is really no longer used, but again if we were to light a fire in the living room, it would trigger the boiler to heat the rest of the house, set at around 17°C in the day, unless alternative heating in the living room, it will not fire the boiler. I was fitted to link to the Energenie TRV heads, but was found they would only follow if the Nest Gen 3 was manually adjusted, if temperature changed by programming, they failed to follow, hence the Wiser wall thermostat in living room.
Although the heating works, it is far from perfect, I have called it near enough engineering, but in real terms, it's not near enough, so tweaking is required.
So as well as settings, it is also what to expect, I know there will be some hysteresis, I can't expect my thermometer on table to read 20.5°C all day, it will raise and fall as the oil boiler cuts in and out, but how much should I expect?
I see flat under house, heating set to stop frost, at 13.2°C, my bedroom at 16.6°C and the living room at 20.1°C and boiler has just kicked in again, wall thermostat set to 20°C showing at 19.5°C, one TRV showing 20.9°C the other 18°C this is in the same room. Summer they all show the same, so it is the way thermals move the air around the room.
I don't understand why condensing vs non condensing boilers, either gas or oil have any influence on the heating, as long as both gas boilers can modulate to the same output, oil boilers continually cycle on and off as they fire flat out. I have a non condensing 20.5kW Firebird with 10 rads, eight with TRVs, the other two are in a combined living/dining room controlled by a digital stat with a hysteresis set to 0.3C, system works pretty well for me.
I was unaware there were any condensing boilers which did not modulate? I was under the impression to gain the latent heat from the flue gases the return temperature of the water is important, but with my non condensing boiler, only the output temperature is monitored.
Mothers house with a condensing boiler, radiators always warm, never really got hot, except when it changed room temperature, it just stayed warm enough to maintain the room temperature.
This house however, the radiators will alternate hot and cool, each time the boiler fires, or turns off, even if the wall thermostat still calling for heat, the boiler has to cool quite a bit before it restarts.
Living room thermometer now showing 19.3°C so must be about time for the boiler to fire again, and I can hear the TRV head behind me, adjusting, so opening the TRV ready for the next boiler firing. Wall thermostat shows 20°C both current and target and the flame, and just hear the boiler fire up as I was witting this.
If the rad area is sufficient the return temperature can be low enough for condensation at boiler design output. And except in quite cold weather it goes off on roomstat before getting too warm. My boiler never reaches control-stat setting on CH, only on HW (W-plan).
