Hi guys,
I'm new to the group, but very impressed with all your advice...and quick wit...
For my first enquiry, I would appreciate your advice in regards to a hardware spec. for electrifying
my garage.
I'm after about 32A at the garage (6A lighting, 6A extra lighting/spare, and 20A radial power - welder, etc).
The distance from the domestic mains supply is 150ft / 50m, and there's already an (RDL) 100A 2x5 way junction box after the mains meter.
This junction box currently serves 32A to main household consumer unit, and 32A switch to a loft conversion.
...So I'm thinking there's just about enough room to fit a 63 Amp 300mA RCD 2 Pole in it's own consumer unit, which would then feed a 50m length of 16mm 3-core SWA to the garage. (I'll use the earth on the core supply cable).
I have every intention of securing the SWA over 3.2m high on the exterior house wall, and then dropping it to waist height, and running it through black plastic elec duct pipe with a wrap around warning tape - this will be attached to concrete fence posts. but hidden inbetween exisitng fence panels.
At the garage end, I'm thinking of a 63 Amp 100mA RCD 2 Pole running to an insulated consumer unit, with separate trip switches for each of the stipulted circuits.
I'd like to run a spur from the garage consumer unit to a plug about 20m's from the garage - to keep it separate from the house.
This pretty lot is going to cost in region of £400-450 from tlc-direct.co.uk - is this the cheapest? and have I missed anything? have I set myself up for ridicule?
Needless to say, all of this will be Part B checked, tested, and certificated - albeit not by me !
..I'm just footing the bill, and laying the SWA cable.
cheers
Deeman
cheers
Deeman
