Thermostat 7" or 11" does it matter ?
4 Dec 2010
Aberdeen
I need to replace the thermostat in an Immersion heater.
IM Heater is Backersafe 09193VS 3kw 14" pack
there is Backersafe thermostat BmST7 fitted, should it not be an 11" thermostat in there ?
or does it matter ?
thanks
or does it matter ?
thanks
Well, it dont matter to me :P
it is in the side, midheight of tank
not sure dimensions of tank ,
but it is in the airing cupboard in a flat
sits 2 feet or so off the floor
with water pump underneath
its a 7"
but the thing is- i don't know whether it Should have been 11"
because there seems to be room for 11" one.
but whether that is such a factor, I'm not sure.
the pump is not pumping, and i suspect its failed - because the thermostat isn't working and the water is too hot.
i will probably just get a new 7" one , as well as replacing the pump.
thanks
Unless it's a thermal store, the pump shouldn't have anything to with the immersion.
Do you have a boiler for the radiators?
its a HW storage tank purely for the taps
the immersion heater works ok cos it heats the tank Ok
but the pump stopped working
only a small output to the taps
the thermostat is probably broken also
i will check it tomorrow
its just that i think ther should be an 11" and not a 7" thermostat inserted.
at present it has a 7 , but there is room for an 11
If the immersion heater is horizontal, the length of the thermostat will make little difference.
If the heater is vertical, or near vertical, the length of the thermostat will make some difference.
Hot water rises to the top of the cylinder, so a vertical heater with a short thermostat will only sense the temperature of the water at the top of the cylinder. A longer one will sense the temperature further down the cylinder.
yes it is horizontal
thanks very much ,
i hadn't thought of that
ill get another 7 and that will be the end of it.
(i hope)
:D
