New property..
I recently had an incident where a family member "broke" the thermostat by using a wall steamer under it. I got a new one, connected it, the lights all turn on ok - but the central heating bodies don't get warm.
The boiler does make noise as soon as I switch the isolator on, but I can't tell if it's doing anything else when the relay on the new thermostat is on or off.
I also removed 3 heating bodies (closing the valves they were connected to)
Now, three things could be wrong here
1. The new thermostat is wired wrong
2. The electrics on the boiler side blew some kind of fuse? (Although I can see power coming through the live wire)
3. The central heating bodies run in series, and when I remove 1 the rest don't work??
Any other explanation? Do I get a plumber or an electrician?
Some information:
Old thermostat: Honeywell T6360B
New thermostat: Honeywell CM927
Connected:
1 -> L (brown)
2 -> N (blue)
3 -> B (red) ?
Heater is a Baxi, will get model when I get home.
I also have a Drayton Lifestyle LPx22 programmer
Some information:
Connected:
1 -> L (brown)
2 -> N (blue)
3 -> B (red) ?
